landyacht318
Sep 30, 2014Explorer
The wire from Unit to alligator clamps is 12 awg which is rated for 30 amps.
The fuse is 30 amps.
The draw varies between 16 and 18.5 amps when running.
Another thing to note, if airing up something already 75 psi, turn on the unit, then attach the schrader valve.
Do make sure to open up the air filter intake holes when it arrives, retorque the head bolts after the first heat cycle. Try not to get frustrated threading the schrader valve attachment.
The air filter makes it much quieter too. Never run it without it attached.
