CheeseEater88's avatar
Mar 01, 2017
12v and 110v and techquestions
Hello,
I have just started to look for my first RV travel trailer and I had a few questions.
First off I am am a bit of a tech lover. I do well with wiring diagrams and schematics, but I just can't find any details to what's inside of the new rvs I am looking at.
I am curios to the typical setup of travel trailers, I am currently really interested in the Venture RV 167vms, I like the pullout and the counter space. Dislike the skylights, and the TV mounting position(I can make a bracket to lower the TV). I assume its not common, maybe just a fluke, but the one I was looking at had wiring dangling free about 10" above the ground and the copper propane lines were looped lower than the rest of the frame
I digress, in my mind they have a 12v battery source, an inverter/charger, and a fuse box...then distribution out to the varied devices. My question I suppose would be what's actually there, and what runs on what? Are the slide out motors operated typically on AC or DC? The water pump? Ect..
Would it be easy to convert the system to 24v or 48v DC for the battery side of things? (it would make it easier to put lots of solar panels on) I can make a smaller loop or use a regulator to send 12v if needed to certain items. (I've been eyeing a 48v mppt/inverter/charger, as I wanted to possibly boondock, and stick crazy amounts of solar to the roof slowly over time...mppt is voltage and amperage limited based on the output voltage, so the higher voltage would allow me more pannels)
Again, I'm in the dark here, if someone with some first hand experience could give me a quick rundown on the typical travel trailer layout.
What ever I buy, I plan on keeping for a long long while, so I want to make it the best I can. That and I might full time in it off and on.
Thanks for all the help!
  • Basically the only thing AC is AC and microwave.
    Fridge and water heater could run off AC or propane.
    TV depends on what was installed in the unit.
    24V or 48V would probably be as easy as running your house on that same voltage.
    Everything is 120 AC or 12V DC so you either need to go up or down.
    I don't know that trailer but it seems kinda small for 4 batteries
    NCC (Net Carrying Capacity) 1,102
    Wires dangling are test points I was told
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 22, 2025
