mrekim
Dec 21, 2014Explorer
When I replace crimp connections that are exposed to the elements on a trailer I find that I have to cut back quite a bit of cable in order to get to good, un-corroded copper. Way more than if the wire was protected from the elements with a good waterproof crimp.
If it needs to be cut it can be cut right at the crimp and should have good copper and not need to be . If there's some concern about length, add wire to make a service loop that can be shortened as needed.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
