mlts22
Dec 26, 2014Explorer II
Where does one find that proper tubing? One thing I've found with crimps is that there are plenty of cheap terminals. However, finding tinned copper ones that only have one end for the wires, so that the fitting is airtight once the tubing is shrunk into place is a completely different story. Same with crimpers. There are cheapies which make cute little marks but eventually will have corrosion or just pull out due to the loose fit... then there are the type which actually "cold weld" the wires to the fitting in a hexagon pattern, so it doesn't fall prey to vibration later on.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
