Tequila
Jun 03, 2015Explorer
From what I can see the white is 12v, it is looped to other fixtures. The black wire on the switch is probably switching ground. Its hard to say, could be the other way around, you need to check it with a meter. Easy to run one between the ground of that electrical fitting and the black on the switch. If you have 12 v then the black is hot. If the switch is sending a ground up, they may have even tapped that electrical outlet for it.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
