westend
Jun 03, 2015Explorer
The jacket color of the wires is secondary as to their purpose. You need to understand what you're trying to accomplish--sending power that is switched to a light fixture and supplying a ground at the fixture so the electrical path is completed back to the source of power. In our case that would be the battery (or through a fused distribution panel to the battery).
Conventionally, white wires are for (-) phase and black is for (+) phase. You only need to switch the black wire to interrupt power to the fixture. A bulb requires a full path to the source of power, hence both (-), (+) phases are present at the light fixture.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
