BFL13's avatar
BFL13
Explorer II
May 07, 2015
12v MPPT and 24v MPPT vs 24v PWM Test
Got a chance to try out comparing amps to the battery using MPPT vs PWM on a 24v battery bank and comparing those with the usual MPPT on 12v with my 230w panel.
The bank is four 6s, so it was easy to change from 12v to 24v and back.
(Was able to swap them all around with insolation etc as near the same over the time it took as you can do in these tests, so the results are useful but not lab perfect of course. )
(The actual amps are not necessarily the max amps for the day with the sun higher later on, but the amps can be compared with each other within the time frame of the tests.)
MPPT controller is the 20a Eco-Worthy and the PWM is the Solar30. Battery bank "resting" voltage before the tests was 12.4 volts, low enough to accept all the amps.
Voltage and amps results as shown on the controller's display, confirmed with multi-meter.
12v MPPT- 12.7v/14.97 amps (190w)
24v MPPT- 25.4v/7.95 amps (203w) so that would be 15.9a at 12v
24v PWM- 25.5v/7.99 amps (204w) (15.98a at 12v)
The MPPT buck converter is more efficient doing 24-24 than 24-12 as we know, and this test seems to show that.
I expected the PWM on 24v to do about the same as it would with 12v for getting amps, which it did here.
The ambient and panel temps are moderate today, so the MPPT was not suffering from high panel temperature so much like it does in July/August here. I wanted to see this summer if I could beat that problem by using the Solar30 with the battery bank in 24v mode.
I have a spare 12v battery to leave the rig on during the day while the main bank is disconnected at 24v. However the mechanics of swapping things around may make it all too annoying.
The lower amps of the MPPT in July are still plenty for our needs, so there is not much reason to do all that work. I just hate not getting "all my amps" so we'll see if it looks worth it this summer when I do another set of tests with the panel being hot.
With the hot panel I expect the 24v MPPT to not do as many amps as the PWM at 24v, which just uses panel amps and they are not reduced by the panel getting hot. We'll see in July!
Having RV issues? Connect with others who have been in your shoes.24,303 PostsLatest Activity: Aug 21, 2025
