SuperDutyFiver wrote:
I agree-sounds so simple but def remove and cleanup all connections(from the plug on the truck to the battery cable clamps in the trailer) before you make yourself crazy!
It depends on who you talk to as my state of mind on this issue. The plug and wiring in the truck is Bargman and is 2 years young. :h
I am gonna give that ground issue some effort tomorrow. Thinking about cutting the connection of white wire s in the box on the trailer and doing it over for grins. Same for the black wire.
And yes will take the ground for the camper completely out and reinstall.
The onboard system via the converter works fine so it has to be delivery from the TV. :h
