RavensFan24's avatar
RavensFan24
12v Wiring Confirmation
I have a 2015 Keystone Premier. I'm getting ready to purchase and install a Fantastic Fan. I checked the RV today to see if it was already pre-wired in the vent port. While it wasn't pre-wired, I did find some wires that were reachable from the port. One went to the LED light and was red and white. The other one I couldn't see what is was connected to, but it was black and white and seemed like the wire may have been a touch thicker than the red and white wire.
Based on my extremely limited electrical knowledge, I'm assuming the red and white wire is for 12v and the black and white wire is prob the 120v for the AC unit which is right near there.
Can anyone confirm or deny that this is accurate? I checked the manual and there was no real info. I know you can tie the fan into the wiring with the lights, so I'm pretty sure the red and white cable will work for my purposes, but wanted to get some confirmation if possible before I start splicing wires.
  • You might want to call Keystone Customer Service. They should have the information. I have a Monaco and call them regularly and get good answers.
  • I spoke with Keystone today. They confirmed that the black and white wire is the hot 12v wire, so I'm good to go.
  • So I installed my Fantastic Fan this weekend. My frustration level was high because the black and white wire that Keystone said was the constant 12v, was in fact not at all a constant 12v. I was able to get a constant 12v from the AC control unit as suggested by another forum member and it worked perfectly. I was able to easily fish the wire across from the AC unit to the vent and the fan worked beautifully. I did have a panic moment though when I went to turn the AC on and my thermostat just gave me an error message. turns out one of the thermostat control wires wasn't in the right spot. Once I fixed that we were golden.
    I think the one thing that most of these Fantastic Vent installation videos nee to spend more time on is the wiring. That's really the main issue for most people from what I've read. Putting it on the roof is easy, but making sure you have the right wiring available and that you're hooking in to the right source is a pain in the ass.
  • My Fantastic Fan simply does not require -that- much amperage to worry about robbing from a convenient pair of wires. The trick is making sure the wires to be robbed from are hot all the time.
    Who in their right mind would wire a dual voltage system with incorrect NEC wire colors?
    The "Hot Setup" is to dedicate primary colors:
    120VAC
    Black L1
    Blue L2
    White L0 (neutral)
    12VDC
    Red Hot all the time. Not swithed at source
    Yellow Battery negative
    Remaining Colors: Switched or dedicated fuse circuits
    You cannot appreciate how much EASIER this makes things years later. Find a color wire then go to the fuse panel and read the function label.
    120VAC
    Black L1
    Blue L2
    White L0 (neutral)
    12VDC
    That's funny cause in my trailer the red 12v was switch based and the purple 12v was the constant.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
