mrekim
Nov 13, 2016Explorer
12x2" Brake differences
I have 5200 lb axles. I'm about to start working on the brakes to deal with a short (according to the brake controller).
I'm considering getting some self adjusting brakes. I see that I can get filled backing plates for 12x2 brakes at 5200 lbs, 6000 lbs, and 7000 lbs.
I've also seen 12x2 brakes for all these rating (5200 through 7000).
Does anyone know the how these differ?
[EDIT]
I found this:
ETrailer FAQ Item
So it seems that all 10x2 should interchange with the higher rated ones have a stronger magnet and different pad compound?
Also, I would assume that if you go to a different magnet/compound you MUST do both wheels on an axle and probably should do all the wheels to keep the braking as even as possible.
[/EDIT]
[EDIT]
I found this:
ETrailer FAQ Item
[/EDIT]
