dougrainer wrote:
Explain further. You first stated the unit would be under a carport. Then you stated an RV Park, and I am not aware of RV parks that have covered slabs for Rv'ers. State what size and type RV you are comparing. Does it have Slide room, or more than 1 slide room. Are they BOTH ducted?  Doug
I won't bother sending a picture, but several of us in this park have carports over our RV's.  Took the roof temperature from 135 degrees down to 95 degrees when I installed it.   Not sure what difference it makes, but it is a no slide travel trailer and I will add that the box measures 26 X 8 since you seem to feel that is important.  Either unit will cool the trailer as that is what I now have with a similar trailer.  The ONLY difference is which AC unit is most likely to be trouble free.   Here is the deal:  A 13,500 btu air conditioner does a good job with my current 26 foot no slide trailer.  I do NOT need more capacity, just the best unit for the same price.  Both units are ducted with wall thermostats.  You seemed to prefer the 15.0 K unit in a previous post.  Are you having second thoughts?
