Boon_Docker
Dec 06, 2016Explorer III
Beau Bo wrote:wa8yxm wrote:
Do what I do.. use a pressure regulator between Compressor and RV. I set mine to 50-55 PSI for blow outs. Remove it from the line for inflation of tires.
This sounds like the way I may go with it. Even in the event all the faucets get closed the regulator should limit the pressure increase.
If you are going to use the Viair 400p to blow out the lines be sure to put RV antifreeze in the lines after.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
