CJW8
Dec 07, 2016Explorer
I have been blowing out my lines for years using whatever compressor I have and setting the regulator at about 40 PSI. I use a male garden hose to schrader valve fitting and a clip on air chuck, connected to the city water inlet. Someone just pointed out to me this doesn't clear the line between the pump and the tank. I do drain the freshwater tank and then run the pump until it is dry. I think this good enough as I have never had a problem.
