Halmfamily
Nov 06, 2015Explorer
13500 A/C on 2000 watt inverter?
My brother is having issues with a 13500 btu A/C starting while using a 2000 watt inverter. This is installed on a cake delivery van. The fan motor will turn on but not the compressor. He is using two 12 volt batteries connected to the vans alternator. The breaker will trip on the inverter when be compressor tries to start.
They were using a 2000 watt generator to run be A/C but don't want the hassle of the generator. He swapped out the inverter and is still having the same issue. Any ideas? Bigger inverter? I personally don't think the vans alternator will be able to keep up the batteries either.
Any help would be appreciated.
