otrfun
Apr 30, 2016Explorer II
jjrbus wrote:All 13.5k BTU a/c units are not created equal. There is a specific reason why some 13.5k BTU a/c's can be reliably started/run with a solo Honda EU2000i while others cannot.otrfun wrote:A little HOnda can start and run a 13.5K btu AC, but not dependably . . .
If you have plans to power your a/c unit(s) with a generator, consider looking at 13.5k a/c units with LRA's lower than 60a. You'll significantly reduce startup issues by doing so.
I highly recommend the Coleman Power Saver 13.5k 9xx series units (not the older 8xx series). Some of these units have LRA's as low as 50a and can be started/run by one Honda EU2000i.
The closer a given 13.5k BTU a/c unit gets to 50a of LRA, the odds of a EU2000i reliably starting/running it (with the Eco mode on) go up dramatically.
FWIW, the vast majority of OEM 13.5k BTU a/c units have 60-68a of LRA---too high for a solo EU2000i to start/run reliably--even with the Eco mode off.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
