pnichols
May 01, 2016Explorer II
Dave (the OP) ... I see that your RV may be about a 30 ft. trailer?
If you were happy with the cooling capacity of the 13.5K A/C unit that was in it, I'd recommend replacing it with another 13.5K unit - but one of the new high efficiency models.
If you drycamp at all, a high efficiency 13.5K unit probably will start and run fine off only a Honda 2000 inverter generator. This a nice way to drycamp comfortably in warm weather using only a relatively small light-weight and fuel-efficient generator.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
