Sort By
- dclark1946Explorer
otrfun wrote:
jjrbus wrote:
All 13.5k BTU a/c units are not created equal. There is a specific reason why some 13.5k BTU a/c's can be reliably started/run with a solo Honda EU2000i while others cannot.otrfun wrote:
A little HOnda can start and run a 13.5K btu AC, but not dependably . . .
If you have plans to power your a/c unit(s) with a generator, consider looking at 13.5k a/c units with LRA's lower than 60a. You'll significantly reduce startup issues by doing so.
I highly recommend the Coleman Power Saver 13.5k 9xx series units (not the older 8xx series). Some of these units have LRA's as low as 50a and can be started/run by one Honda EU2000i.
The closer a given 13.5k BTU a/c unit gets to 50a of LRA, the odds of a EU2000i reliably starting/running it (with the Eco mode on) go up dramatically.
FWIW, the vast majority of OEM 13.5k BTU a/c units have 60-68a of LRA---too high for a solo EU2000i to start/run reliably--even with the Eco mode off.
That is consistent with my tests. I was able to reliably start and run our Coleman 13.5 PS with our EU2000 in 97 deg ambient temp. - vandaveExplorerThanks for all the post. Since the Arctic Fox is so well insulated, the 13.5 works well. I run it off 2400 Yamaha inverter with no problems(I don't use much else besides lights and T.V.). We'll be taking this information when I need to replace it. The unit is 10 years old.
- pnicholsExplorer IIDave (the OP) ... I see that your RV may be about a 30 ft. trailer?
If you were happy with the cooling capacity of the 13.5K A/C unit that was in it, I'd recommend replacing it with another 13.5K unit - but one of the new high efficiency models.
If you drycamp at all, a high efficiency 13.5K unit probably will start and run fine off only a Honda 2000 inverter generator. This a nice way to drycamp comfortably in warm weather using only a relatively small light-weight and fuel-efficient generator. - otrfunExplorer II
jjrbus wrote:
A friend of mine has had great luck powering his Coleman Power Saver 9xx series 13.5k BTU a/c with his solo EU2000i. LRA on his particular unit is 50a.otrfun wrote:
Dometic Brisk Air, model 57912.602 LRA 48.3. Works well in cool weather, will not start and run in hot humid weather with hard start capacitor installed with eco mode off. I am in SW Fl at 10 feet
elevation.
Which AC are you running with your HOnda?
As for your Dometic, it would be helpful to make some inrush current tests using both commercial power (to establish a good baseline) and generator, to determine whether your a/c unit, wiring/connections, or generator are performing properly. - jjrbusExplorer
wa8yxm wrote:
Make and Model? First. if it's more than a few years old you might want to looks at some of the 15000 BTU jobs.. I replaced a 13.5 with 1 15K and the amazing thing is the power draw is ..... Identical.. More cool, same watts.
Why Upgrade. Well It's getting hotter out every year, Record breaking heat waves.
Now: What's wrong with your A/C.. in my case it was catastrophic failure of the cooling uint. (THe part that is above the roof) Carrier (Mine are Carrier Air Vs) no longer makes RV air conditioners so a direct replacement was not possible (Having seen how they bungled my unit (Died of a factory error) I'm not surprised they left the field)
I was able to get a "Drop on" replacement though. Mine is Advent air (I do not recommend) I believe one of the companies that start with "C" also makes one that fits. What I forget is which company.. But a good dealer will know.
Curious why you would not recommend the Advent? I have been watching them for a bit. Jim - jjrbusExplorer
elevation.
Which AC are you running with your HOnda? - wa8yxmExplorer IIIMake and Model? First. if it's more than a few years old you might want to looks at some of the 15000 BTU jobs.. I replaced a 13.5 with 1 15K and the amazing thing is the power draw is ..... Identical.. More cool, same watts.
I was able to get a "Drop on" replacement though. Mine is Advent air (I do not recommend) I believe one of the companies that start with "C" also makes one that fits. What I forget is which company.. But a good dealer will know. - otrfunExplorer II
FWIW, the vast majority of OEM 13.5k BTU a/c units have 60-68a of LRA---too high for a solo EU2000i to start/run reliably--even with the Eco mode off. - jjrbusExplorer
A little HOnda can start and run a 13.5K btu AC, but not dependably.
My Honda will start and run my 11K AC with a hard start capacitor when it is cool but not when the tempature is in the 90's with high humidity! - otrfunExplorer IIIf you have plans to power your a/c unit(s) with a generator, consider looking at 13.5k a/c units with LRA's lower than 60a. You'll significantly reduce startup issues by doing so.
Having RV issues? Connect with others who have been in your shoes.24,241 PostsLatest Activity: May 07, 2025
