Micro1706's avatar
Micro1706
13,500btu a/c on a Yamaha 2400iSHC genny? Hard Start Kit?
We just got a new yamaha 2400iSHC genny, after being told it would power the 13,500btu Dometic a/c on our brand new Winnebago Micro Minnie 1706fb trailer. It did not! When the a/c kicked on the overload light lit on the genset and that was the end of that. The a/c then did not go on. And the generator has to be turned off once the overload light goes on, then re-started. The same process repeated, got the same results.
However, it was a very hot day here today...around 93, and the 1706 sat in the sun all day. When I ran the test, it was very hot inside the trailer.
so, decided to run a test: connected to city power, ran the a/c just fine, cooled down the innards of the trailer, then shut down the a/c, connected the trailer to the running genset, and yes, it ran the compressor just fine when I then turned the a/c on. And has been cooling it for the last hour.
Now...would it not be advisable to get a Hard Start Kit (something like this: Supco SPP6E E Series Electronic Potential Relay Style Hard Start Kit, 1/2 - 3 Horsepower Range, 88-106F Capacitor Size), as someone once suggested when we were considering the generator? If so, how does one go about this? Would it be advisable to take it down to the local r/v mech. shop and ask them to do the install?
I have been told it helps protect the compressor or extends its life. Is there much truth to this?
Any suggestions, advice, or insight will be very gratefully appreciated.
Many thanks
Bob
