klutchdust's avatar
klutchdust
Explorer II
Feb 15, 2019
14 volt tv and the inverter squealing.
My Cambria has a 14 volt/35W TV in the bedroom.(typical power 18W) It is powered by a Samsung ac/dc adapter ( 35w) and that is plugged into a Wagan Elite 400W pro dc to ac pure sine inverter.
Now, when it was first installed the tv operated off of the house batteries. Now when it is powered on from the house batteries there is a loud squeal. The inverter does say that IF the input power drops the inverter may make a beeping sound then it will power off.
The house batteries are fully charged when this happens. The 12 volt input power to the inverter is controlled by a wall switch factory installed.
What went wrong.
  • OP seems like someone who would appreciate a Trimetric.
    I do have an adapter for paralleling the engine battery with the house battery bank, but I prefer to use a separate maintenance charger on the engine battery. I don't like having the engine batt in parallel with my house AGMs, but cannot prove it is a bad thing--I just don't like it. I made the adapter for when on solar off grid a long time so the solar would also do the engine batt.
    I found it way easier to leave the 7300 in place and use a deck-mount converter as a portable charger with clamp-on wiring (cut off end of fat jumper cables). No wiring to do, and you get the charger close to the batteries. The 7300 was still good for when on shore power.
  • I'd not long term keep a flooded starting battery attached to an RV converter set to keep house AGMs at a happy float voltage.
    Flooded batteries are more of a 13.2v float and AGMS 13.6v ish.
    I have verified that my 13.6v recommended float AGM will discharge slightly at 13.5v float when there are still loads on the system, or temperatures sub 60f.
    BOats use amn 'echo' charger to keep starting battery happy when attached to shore power.
    Lots of ways to skin that particular cat.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
