So we are looking at a long term 15 amp site . Never have camped at 15 amp site before only 30 amp . So what issues am I going to find ? Can I run my AC ? Can I run my AC on low and use a 1000 w...
a 1000-watt microwave will consume 8.3 amps (assuming source is 120-volts AC). that's 50% of your available amps. but depending on the load at the campground you may have less than 120-volts. at 115-volts you'd be consuming 8.7 amps. I seriously doubt that you could use the AC with the microwave.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
