So we are looking at a long term 15 amp site . Never have camped at 15 amp site before only 30 amp . So what issues am I going to find ? Can I run my AC ? Can I run my AC on low and use a 1000 w...
Watch the voltage stays at 108+ in the RV if running the air. I would turn all other breakers off while cooling.
4 to 6 batteries and an inverter would give the power you need for a time... then you would need to let the converter charge the battery. Possibly about 450 watts of solar could keep that battery up while you use the 15a for the air. It will cost some real money to make these systems workable.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
