- Bill_SatelliteExplorer II2 - 30amp plugs work great. Most anything else will not.
- Retired_JSOExplorer III have a Y adapter which I bought just to use in Georgia State Parks that are not equipped with 50 amp service. Most pedestals in GSP system not 50 amp have an additional 30 amp plug which allows me to get 30 amps on 2 legs, enough to power both heat pumps.
ecguyer wrote:
so then the y Adapter is no good because all of the parks have a GFCI on the 20 amp side. is their no way around this?
Current electrical code requires the GFCI in the circuit even if you don't see it in the box. If the campground has old wiring and does not update any part of it I believe they don't have to come up to code until they do.
If there is a GFCI anywhere in any circuit used the Y connectors will trip it immediately and there is no way around that. The last time I was able to use mine was when we were in a park where the 50 was not working properly and I used the 30 amp in my box and ran an extension from the 30 amp in the site next door. I still didn't have 50 amp service but as long as I limited each leg to 20-25 amps I was OK. - Dusty_RExplorerIf the 50 amp is not on a GFCI then it will work.
- ecguyerExplorerso then the y Adapter is no good because all of the parks have a GFCI on the 20 amp side. is their no way around this?
- Roger10378Explorer II
mkirsch wrote:
Why does a Y adapter trip the park's GFCI circuit?
Later this year I am going to an event where the site is VERY crowded, and all the 30 and 20 amp sockets are certain to be in use. The 50 Amp sockets go largely unused.
I have purchased a 50 Amp to 2x30 Amp Y adapter in anticipation of this, so that I and a neighbor can share a single 50 Amp outlet.
If this isn't going to work I am not going to be happy, as the adapter was not cheap and it's too late to return it.
This direction works great. It is the one that hooks a 50amp trailer to a 30 amp plus a 20 amp GFI that does not work.
A GFI measures the current on the hot and neutral and compares them. If there is the slightest difference it trips. With an adaptor there are two neutrals so there will be a difference and it trips. - mkirschNomad IIWhy does a Y adapter trip the park's GFCI circuit?
If this isn't going to work I am not going to be happy, as the adapter was not cheap and it's too late to return it. - wa8yxmExplorer III
Fishinghat wrote:
The GFI (ground fault interrupter) outlet in your RV is not dependent on the 120 volt power plug adapter's, unless you have disconnected the ground or crossed the wires somehow.
True but not applicable
The question is how to get it to work with the GFCI in the park's outlet box..
These cords will trip the parks GFCI, not yours, if the park's GFCI fails to trip, it is defective.
HOWEVER,,, there are some older parks that do not have GFCIs. works there. - 1492ModeratorMoved from Forum Technical Support
- AllegroDNomadWon't work. Will effect the CG GFCI CB, not the RV.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
