pirlbeck
Apr 22, 2017Explorer
2oldman wrote:pirlbeck wrote:I don't know of any way to add bypass diodes to a panel, which is where they go.
.. series and use a MPPT controller. If done this way, I would want to add some bypass diodes to the wiring to limit the effect any shading had on the output.
I think in this case the bypass diodes would have to be installed in the wiring, most likely in the combiner box. I have read a little about it online and if I understand what I read correctly, the best way is to have panels with multiple bypass diodes built in, but putting them on the panel output is better then no bypass diodes at all when wiring in series.
If I am misunderstanding this more input or corrections to my thoughts are welcome.
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,379 PostsLatest Activity: Apr 13, 2026
