rk911
Jul 25, 2019Explorer
fj12ryder wrote:
Just get a 50 amp to 30 amp adapter. You plug your 50 amp plug into it and then into the 30 amp pedestal. Easy peasy.
and no, a 50-amp RV pedestal is not 220-volts. it is two separate legs of 120-volts, each leg capable of supplying 50-amps. you can safely connect your 30-amp RV to the 50-amp RV pedestal using the 30-female/50-male dogbone adapter
Having RV issues? Connect with others who have been in your shoes.24,379 PostsLatest Activity: Apr 13, 2026
