Dutch_12078
Jul 26, 2019Explorer III
rk911 wrote:fj12ryder wrote:
Just get a 50 amp to 30 amp adapter. You plug your 50 amp plug into it and then into the 30 amp pedestal. Easy peasy.
and no, a 50-amp RV pedestal is not 220-volts. it is two separate legs of 120-volts, each leg capable of supplying 50-amps. you can safely connect your 30-amp RV to the 50-amp RV pedestal using the 30-female/50-male dogbone adapter
Maybe you should take a look at the next RV park pedestal you see with a 50 amp outlet. Notice that it has "120/240V" embossed or molded on it. Newer outlets may have "125/250V" on them. You may even notice that it's exactly the same NEMA 14-50 format that 120/240 volt residential ranges plug into. There is nothing special about the outlet or how it's wired for RV use compared to normal residential use.
Having RV issues? Connect with others who have been in your shoes.24,379 PostsLatest Activity: Apr 13, 2026
