fj12ryder
Jul 28, 2019Explorer III
DSteiner51 wrote:So if I'm reading this right, if I plugged my RV into the dryer outlet, if it fit of course, no harm would come to my RV because they're both 240 volts? Correct?rk911 wrote:fj12ryder wrote:
Just get a 50 amp to 30 amp adapter. You plug your 50 amp plug into it and then into the 30 amp pedestal. Easy peasy.
and no, a 50-amp RV pedestal is not 220-volts. it is two separate legs of 120-volts, each leg capable of supplying 50-amps. you can safely connect your 30-amp RV to the 50-amp RV pedestal using the 30-female/50-male dogbone adapter
My house has 2 120 volt wires come into my main breaker box and a double 200 amp breaker. Farther down are several double breakers, 1 for the dryer, 1 for the range, 1 for the well pump, and 1 for my 5th wheel. In my 5th wheel the main breaker is again a 50 amp double breaker. If in fact my house is 240 volts and my dryer, range, and well pump, then my 5th wheel is also 240 volts. When I use a volt meter and jump between my two hot bars in my RV it reads 240 volts. Horrors!
Having RV issues? Connect with others who have been in your shoes.24,379 PostsLatest Activity: Apr 13, 2026
