fj12ryder
Jul 29, 2019Explorer III
SoundGuy wrote:Yes, I know. I was trying to make a point about DSteiner51 stating:fj12ryder wrote:
So if I'm reading this right, if I plugged my RV into the dryer outlet, if it fit of course, no harm would come to my RV because they're both 240 volts? Correct?
Your RV is wired for 120 vac main service, NOT 240 vac. What do you think will happen if you plug your 120 vac trailer into 240 vac source power? :E
"If in fact my house is 240 volts and my dryer, range, and well pump, then my 5th wheel is also 240 volts. When I use a volt meter and jump between my two hot bars in my RV it reads 240 volts. Horrors!"
