Larryect
Jun 18, 2017Explorer
wnjj wrote:Larryect wrote:
That looks like an interesting idea. However it's not just the start up. I did get it started once or twice. But, there was no additional running amps left over for anything. If I even turned on my LED lights the generator would bog down.
That device looks like it would be good if two 2000's were having trouble starting it.
I assume you mean 12V LED's? If they cause your generator to bog, try turning off the converter. That alone takes a bunch of power and may be most of the issue.
True. But the point is if I want to run the AC I couldn't do anything else at all while enjoying the cool air. No TV, battery charging, limited lighting.
