wa8yxm
Mar 21, 2021Explorer III
The short answer is yes. but.. Be careful.
First you will newed to turn off most everything
Second the wiring in your RV is likely not up to "Grade" for that oven. you may burn out the outlet or an up-line outlet it's plugged into.
My RV was a 50 amp and I added "Kitchen 2" circuit. New breaker 12ga wire, GFCI *15/20 amp model* and a daisy off the gfci 15/20 outlet.
NO overheated wires on that line
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
