RRRDAD's avatar
RRRDAD
1984 carriage brake magnets
Hi. I have a 1984 carriage fifth wheel camper and I need to replace the brake magnets . The brake magnets have a little different look to them they are not the typical round or oval look does anyone know where I can find this type of magnet or have any suggestions on other magnets I can use? In addition if anyone knows how to post a photo on here I can sure do that to help out
  • You are much better off, replacing the entire brake assembly back plate.
    Some of the older axle manufacturers have been bought up or gone out of business making finding exact parts for that brake assembly difficult or impossible to find.
    New backplates gets you not only new magnets but shoes plus all the mechanicals and is fully assembled. Just remove 4 nuts holding the backplate to the axle and the old assembly falls off.
    You will need to get a left and right assembly, don't mix them up.
    This one in the pix is for 3,500 lb axles which use 10" drum 2.5" wide brake shoes.
    Found HERE for $130 for a pair (Left and Right)
    Back plate assemblies are fairly universal and fits quite a few different axle manufacturers (including old defunct axle manufacturers).
    Select via the size of the brake drum, typically 2,000 lb axles will have 7" drums, 3,500 lb axles will have 10" drums, 5,000 lb axles will have 12" drums..
    Whatever you decide to do, do BOTH L and R sides at the same time, otherwise you will have uneven braking which will pull to one side.
    So what is the shape? A photo would help. Here are some photos: Photos
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 22, 2026
