Gjac
Dec 17, 2013Explorer III
My son took the van to a transmission shop and the mechanic took it for a ride after explaining all the usual problems with sensors causing hard shifting. His conclusion was that it was a misfire in the engine. I would not have suspected that since plugs, wires, cap & rotor were just changed. But he suggested changing the coil. His thinking was high rpm when you get on it it shifts well but at lower rpm the coil was not putting out sufficient voltage witch caused a slight misfiring and a hunting of the trans before finally shifting hard into gear. Will check the coil out tomorrow.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
