westend
Dec 27, 2013Explorer
It sounds like you have a couple of valves sticking in the valve body of the tranny (not too atypical with a rebuild). You have most of the symptoms--hard or sticking shifts, hard engagement into gear, excess pressure.
If you're lucky, the rebuilder will stand behind his work. If not, a used tranny is probably the most economically efficient way of dealing with it.
Good luck with the van.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
