dougrainer
Sep 11, 2016Nomad
HOW do you know it is a malfunctioning oil pressure switch? Besides, you just remove the wire from the switch and ground to disable it. IF you have an oil pressure problem and your engine burns up, how much money do you think that will cost you? TOO much oil will cause intermittent oil pressure switch problems as well as too little oil. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
