IB853347201
May 14, 2025Nomad II
Yes, it sounds like it is running warm to me. Being a 1996, have you checked the rad coolant level or flushed the coolant regularly? it's likely the green stuff that doesn't last that long. Could also be your thermostat needs changing?
- duck1973May 14, 2025Explorer
Coolant level is good. But may flush it and start fresh. May change thermostat at same time just to eliminate that as a possibility. No better time to do it I suppose.
