dad4papa2's avatar
dad4papa2
1996 Damon Intruder AC Question
My heater and AC Blower motor has quit working on my 1996 Ford F53 Chassis. I had lost the high speed some time ago but was ok with the lower levels as they were sufficient for my needs. However I went out 2 days ago and warmed up the MH and the fan would not work at all.
Here's what I have checked so far.
1. Checked the fuses under the hood in the power box. All Good.
2. I unhooked the 2 wires from the fan motor and made jumper wires to hook up to it and ran them out to the battery direct. The motor took of in high and I let it run for just a couple seconds. So this should out rule the motor being bad.
So what do I check now??? I see that there is a resistor supposed to be on it but I don't see one yet. I will look further into that today to see if I can find it.
Does anyone know where it might be located at??
Any other input is welcome!
Thanks Much Dad
