IB853347201
May 14, 2025Nomad II
Yes, it sounds like it is running warm to me. Being a 1996, have you checked the rad coolant level or flushed the coolant regularly? it's likely the green stuff that doesn't last that long. Could also be your thermostat needs changing?
duck1973
May 14, 2025Explorer
Coolant level is good. But may flush it and start fresh. May change thermostat at same time just to eliminate that as a possibility. No better time to do it I suppose.
