christopherglen
Aug 06, 2013Explorer
only problem I see with running two chargers is they may drop out of "boost" mode earlier thinking the batteries are near full, as it takes less amps to maintain a set voltage. Once the actual battery voltage climbs high enough, they will taper amperage to maintain it, then shift to float voltage. With the batteries say 80% charged you don't want the charger dropping to float mode because the amps going out of the charger got to low.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
