time2roll
Jul 13, 2015Nomad
westend wrote:My 2000w draws about 1800 milliamps at idle. The 300w draws 160 milliamps. It does make a difference when left on continuous. Especially if solar is marginal.
A good 2K PSW inverter will draw around 1 amp at idle (unless equipped with an idle circuit to minimize draw). A 300W inverter will consume about 500 milliamps at idle. The difference is so small that you won't notice the difference in draw. Having one inverter obviates the use of switches, transfer switches, and any additional wiring which can also fail.
Besides the OP's 300w is already installed.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
