RLS7201
Sep 26, 2020Explorer II
MrWizard wrote:RLS7201 wrote:
1985 is probably stand alone propane, just like a home water heater. No 12 volt required.
Richard
Your thinking 1970's and earlier
By 1985 everything had electric ignition and 12vdc control boards
NO! I was thinking the 80s.
As per Doug's post.
vintage 1985 is just when Dometic came out with the AES model refers. AES stands for Auto Energy Select. They had a an ON /OFF switch with an indicator light. MANUAL Dometic Models, you had to HOLD the Pilot button and then continually push a Manual Piezo lighter button. If the OP has just an ON OFF switch, then he has an AES and requires a 12 volt source to operate. If he has to push in a button and then continually push the LIGHTER button, he does not need a 12 volt source. AS always, MODEL is required to correctly answer his question. Doug
Richard
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
