dougrainer
Sep 27, 2020Nomad
BFL13 wrote:
Thanks for the ideas! I already had the episode where the back outside was hot on 120 but the fridge stayed warm. Turned out to be not level enough. This little fridge is very fussy about levelling, moreso than the taller fridges in our other RVs.
I have a Kill-A-Watt, which I used to tell if there was any draw from the fridge when on 120v, but no convenient way to leave in as a display. I like the indicator lamp idea.
Can't hear any flame. You have to stand on a chair to raise the outside panel, and unscrew the metal cover over the burner to see the flame. PITA. I need to work on a shade for the reflector so you can see if it is lit up when it is not dark in the camper.
The OLD Instamatic refers from the 70's and very early 80's, had to be almost perfectly level to cool correctly. What may look like level enough may be out of level enough to slow good cooling. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
