pianotuna
Jul 06, 2021Nomad III
Tom/Barb wrote:Yes, they are.
If you have room?? gofer it... they are big batteries.
Ivylog wrote:Nice! Source? Configuration? BMS?
I recently built 600AH of Lithium batteries for $1200 and my time… probably 10 hours and not that hard.
otrfun wrote:Oops.
This particular $799 200ah Ampere Time LifePo4 is only capable of producing 100a of continuous current. If you have plans to power a microwave or similar device, you may come up a bit short.
2oldman wrote:FWIW, the $979 ($50 off right now) 200ah Ampere Time LifePo4 "PLUS" version you asked about earlier is rated at 200+a of continuous current. This unit weighs ~6 lbs. more than the $799 (currently $40 off) 200ah unit, but has the same dimensions. Possibly the same cells as the $799 unit. No doubt more capable BMS and cabling.otrfun wrote:Oops.
2oldman wrote:otrfun wrote:Oops.
pianotuna wrote:Yes, 280a. But, for only 5 seconds.2oldman wrote:Strange as the advert suggests 280amp Max.otrfun wrote:Oops.
afidel wrote:Good point. Many of these budget LifePo4’s use sub-par BMS’s with terrible (sometimes non-existent) protection parameters and undersized internal cabling. Not so obvious is the probable use of lower grade cells.
So reading their reviews the BMS is a complete PoS. No low voltage cutoff, no low temp charge protection, etc. If you're going to monitor it closely or have a smart system upstream that can monitor and protect it then go for it, but as a throw it on the tongue and forget about it solution it's a complete fail, you'll most likely end up roaching the cells about as fast as a lead acid for 3x the cost.
