kmb1966
Jul 15, 2015Explorer
Fleet Man wrote:
Have you down loaded the hydraulic schematics for your system from the HWH website? Have you tried selectively opening the valves on the jack solenoids? There is a shuttle valve in the system, located between the jacks and the solenoids which all fluid must flow through. Your problem may be there since all four jacks are affected simultaneously.
I have opened the T-valve (there are 4) and that does not seem to have an effect on allowing the jack to retract. I'm not sure what the shuttle valve looks like or where it is.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
