dougrainer
Jul 29, 2015Nomad
kmb1966 wrote:
I removed the shuttle valve. 3 Jacks still down. Removed the 4 lines. 3 Jacks down. I guess I have 3 bad jacks.???
I find it hard to believe you would have 3 BAD jacks. Where did you remove the lines? At the main manifold? Are the jacks lifting the RV or are they just clear of the ground. IF they are clear of the ground, then I could see 3 jacks stuck down due to defective internal seals, BUT, you should be able to pry them up with a long lever bar and then retract fully with a floor jack once they are high enough to get the jack under the pads. When you removed the shuttle valve, did you reinstall the new one? Do NOT reinstall the old shuttle valve. The seals are damaged. Doug
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
