MEXICOWANDERER
Nov 25, 2017Explorer
Sure would not drive it. This is the 90 degree angle radiator, right? Fan is remote belt driven? Not specific to yours but I used foam sponge to hang the shroud up out of the way when I unbolted the drive shaft pier. Whatever it took I stuffed long skinny sheets of paneling between the blades and the radiator and sure as heck I fumbled it jamming a blade into the paneling and not into a tube. My Horton is a nine blade steel and it took one person on each side to position it. But this is on an 855 NTC which is a lot bigger everything. Be careful. Fans bite. Broken fans have sharp edges. Best of luck. Yes mine is a hydro-loc
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
