Ivylog
Sep 09, 2015Explorer III
Are you sure you only have one fuel filter... Most Cummins have two. Last summer I had much the same that changing both filters and the lift pump did not solve. Away from puter so do a search by me for lift pump and more than a year ago for my $10 solution.
*Back on line so read this and what codes are they getting from the engine? Mine was computer code check... 329.
I do not believe a clogged air filter would get you down to 10 mph plus is the filter minder in the red?
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
