lanerd
Jun 21, 2013Explorer II
Incandescent or florescent or both? I don't know if any 12v circuit breakers...those are usually reserved for 120vac. The 12v system uses fuses to protect them and if one goes out....it's out. There's no in between. Sounds to me like you're having a problem with the transfer switch or converter. Are you connected to shore power? Does it do the same thing while on your generator? Have you measured your voltage?
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
