MNtundraRet
Apr 23, 2024Navigator
LandlordByDay wrote:Can anyone help me diagnose my issue. When my battery is connected I get power to everything other than the ac system, but when I switch to shore power and plug in I get nothing. I opened up the fuse box, checked them and they're all good. Checked the fuses in the power converter too. Is it a bad power converter? Or how do I trouble shoot and diagnose the issue?
1) What kind of RV are you talking about.
2) How many batteries? For many RV's, a battery only powers the DV 12-volt circuit. No 120-volt AC items.
3) If plugged in to an outside AC 120-volt outlet, did you check ti see if it was supplying power? Turned on? Wired correctly? Use an AC power tester!
