Harvard's avatar
Harvard
2004 Onan MicroQuiet 4000 Rides again....
It would crank over but would not fire.
So:
1. Checked throttle linkages and choke for freedom of movement.
2. Pulled fuel line and checked for fuel with primer switch.
3. Pulled the plug, dry as a bone.
4. No fuel fumes in the exhaust.
Still no fire. So, its got to be the carb. Oh Boy, that's like work :)
Pulled out a make shift steel hammering stick and gently tapped the carb while cranking and presto, it started.
One Happy Camper. :B
  • Thank goodness for hammers !!!!..... I'm glad it was an easy fix for you and I'll file this one in my generator file.
  • j-d's avatar
    j-d
    Explorer II
    Just shut ours off. Had a power outage at the campground, back on.
    Friend bought a new carb for a bigger ONAN, Emerald 5500I believe, and the hinge part of the plastic float was binding. Had to file a little bit of plastic 0ff so it could drop.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
