97roadrider
Aug 07, 2017Explorer
Thanks for your help.
I have opened up the belly and discovered that when the button is pushed to bring the slide in the motor twists and I can see where the bolt is sheared off. I have to get the motor & the gear bracket out so I can hopefully remove and replace the sheared bolt. The motor is placed above the cross tube for the other rack and there is a gear on a shaft that I have to determine how to remove.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 19, 2026
