Many RV's have the bed on hinges so you can lift it up. Since yours appears to be bolted down the disconnect is probably not located there.
Did you drop a number in typing in the power converter reading? The converter should be putting out at least 13.5 volts. I'm assuming you just dropped the 3 since the systems work under shore power.
Definitely pay attention to the voltage readings as they might clue you in to something being wrong. Start with a reading at the battery and write it down. You already said 12.5v, so you have at least that much info. So now when looking for voltages you are looking for battery voltage (whatever number that you just wrote down) and not just 12v. If something reads lower you have high resistance possibly from a corroded terminal.
I would definitely focus my troubleshooting to the solenoid that you mentioned. You mentioned you have a multimeter which is good. For the following tests you need a short piece of wire to function as a jumper wire. I typically use a small wire with alligator clips on each end. It doesn't need to be large gauge if you turn off large power hungry appliances first. Something like in the link below should be more than sufficient.
Are you saying there is only 12 volts on one of the three terminals? Assuming the one terminal that has voltage is one of the large wires coming from the battery you should be seeing battery voltage there. Try using the jumper wire and jump between the terminal with voltage and the smallest terminal on the solenoid. If the solenoid is good you should see battery voltage appear on the second large terminal. If the solenoid is bad you will still have a lack of battery voltage on the second large terminal. If you now have power on both large terminals do you have power in the RV? If the solenoid tests good then you have a problem with the disconnect or some other switch is supposed to turn on the power.
Assuming you have a good solenoid and a suspect disconnect do you have battery voltage on one of the two wires on the disconnect switch? If so try dong the same thing as above and use a jumper wire to jump between the terminals and see if the RV now has interior power? If so replace the disconnect switch.
As an aside a battery at full charge is about 12.65 volts. 12.5v is 90 percent charged. It's not a huge deal at 90% charge but if you can't get things working I would put a standalone charger on the batteries to get them charged up. Lead acid batteries sitting partially discharged are getting slowly damaged.
